Same thing happens if the IVR is not grounded.. If the contact stick closed it sends to much voltage and overheats your gauges
RTE limiter - rte
These people sell a solid state replacement and have great installation instructions. Did mine 2 years ago, works great. Btw this is a great time to replace your dash lights with leds also.
There's your problem... Our 50+ year old dashes HATE led lights. Oh wait that's just me!Thanks! I already have LEDs
The oil gauge would surely go to max. Because the limiter is puttng out more due to a short circuit, the other 2 gauges would climb some. Maybe not to max rapidly but some.how that would effect the other guages?
so what was it the ground? Only asking because I'm into mine. I feel like Ive had my dash out a hand full of times and I m getting sick of it...
I also have a ground wire that I am going to terminate in the steering column bolts. when I think about it its my own fault Ive had it out , i didnt do it right years ago. Now I he resoldered pins, did the LED upgrade replaced lamp sockets etc.
i also did some under dash wire repair. Soldered and shrink wrap no butt connectors.
If the IVR / instrument cluster is not grounded the IVR provided 12 volts to the gauges
New aftermarket gauges would be an improvement. No way I would trust 50+ year old gauges unless I absolutely had to.
The gauges worked finse until I had the initial "smoke incident" :S. I like the look of the original Rallye gauges they look awesome from my perspective and still work after 52 years.
I saw a setup somewhere in this forum from Dakota Digital that looked very close to the original look with modern components, unfortunately it was a custom made set of gauges, I looked in their web page but is not listed yet. I have not taken the time to call them ans ask them how much it costs
You can leave OEM ones in place and add a triple gauge set under dash, that way it retains OEM look with new reliability.
You dodged a bullet so far with smoke incident in my opinion.
Good luck.
