That's what we did with our 67. We didn't trust 50+ year old gauges. Left stock ones in(rally gauge) and mounted new Autometer triple gauges(volts, coolant, and oil psi) directly above console and attached thru existing bolt to factory ac diffuser. All apart right now but looks great and NOT put of place.
I would be interested to see your setup. I want to have my dash gauge work but in my attempt for a "70s" theme hot rod I kind of feel the gauge pod under the ashtray area is kind of a nod. Ill be running those stewart warner 'greenline' jobbies, Ill also put my air/fuel ratio gauge in there.
