1969 Race Dart w/ 426 Hemi- garaged for 45+ years
Thank you for taking us all along on this wild and crazy and pretty damn expen$ive journey!
Can't stress enough what an incredible job you and Sean have done with this project. Your Father in law is absolutely beaming with pride as he watches your progress!
Thank you Randy! :thumbsup:
I picked the wrong year to build my car. lol
I thought mine was pretty cool at first, but watching you put yours together is truly awesome and amazing. Congratulations!
Just got off the phone with Sean and the car is done!! He is going to change the oil one more time and I go down to NC to pick it up the week of Aril 22nd. Going to pick a couple of nice days for the drive, don't want to be driving back in the rain.
I can not say enough, how thankful I am for all Sean has done. Sean rebuilt this car, the amount of work he has done and the time he has invested is unbelievable! For those who do not know, Sean is a one-man engine shop. His shop is SB Engine and Machine in Concord, NC.
I appreciate all of you following this journey. Thank you for all the encouragement and information along the way............................. :thumbsup:
Credit where credit is due. Well done Sean (formerly @replicaracer), wish you were still here. And Scott, thanks for taking us on this journey with you.
They have had bad storms like us the last couple of days. He is hoping to move the car outside today to clean up in the shop and hopefully, I will get some more pics............... One of the hardest parts about this build is my being 6 hours away.................:BangHead:
"One of the hardest parts about this build is my being 6 hours away.................:BangHead:"
Well, that and those dollar signs jumping out of your wallet...... :poke: :rofl: :rofl:
This is no different than an archeological dig performed to carefully and methodically bring forth an historical treasure that time has buried.
My build has had me researching and reading many other build threads, some have taken YEARS to complete. Since we have members here from around the country and other parts of the world, I thought it would be fun to hear your thoughts on the cost of a Restoration/Preservation like this. What do you think it would cost to bring it to a professional shop to complete?? Another question and I think I know the answer, would everything be completed so quickly................:thumbsup:
Here is a rough estimate of what it took to complete the project:
1-remove engine, transmission, steering column, and entire front suspension, reassemble suspension to make car "roller"
2-disassemble engine and inspect
3-rebuild engine complete, including machining cylinder heads for missing bolt holes and rocker stand interference
4-modify new carburetors for cross-ram, throttle shafts, bowls, jetting, and air bleed modifications
5-hand fabricate fuel lines like original Hemi style
6-make 2 trips to the dyno facility to set up, and breakdown the engine
7-replace torched-out transmission cross member, with new AMD donor.
8-replace torched factory transmission hump with new AMD part
9-fabricate and install floor reinforcement plates for bucket seats.
10-remove and install seat brackets previously installed upside down, and redrill proper bolt holes
11-clean blast and paint K member, weld reinforcements on lower control arm pivot
12-rebuild front suspension, replace bent LH upper control arm
13-fabricate and install all new brake headlines
14-install line lock and setup for flex hoses to master cylinder
Modify the "E" body radiator to fit, including adapter plates for the fan shroud
15-modify "440" alternator brackets to fit HEMI water pump housing
16-rewire engine bay, convert to 70 up dual field alternator
17-wire up trunk-mounted battery wiring
18-cut-out ladder bars welded solid to axle housing and bolted solid to chassis
19-run new fuel line
20-install MSD ignition system
21-recurve Mopar distributor
22-remove and install the engine 4 times to modify various areas for clearance
23-shorten one shift rod to the correct length
24-fabricate exhaust system to rear axle
25-replace rear axle yoke
26-remove and disassemble the steering column, shorten the tube, reweld, and paint. Reinstall column
27-Modify RBRE valve covers for clearance to rocker stands
28-modify Z bar transmission bracket to raise the Z bar
29-modify chassis side Z bar plate to line up Z bar
Let's hear your thoughts........................
Welcome to the trials and tribulations of building a hot rod. Think about all of the old timers who didn't have the references we have in the electronic age. LOL
I'd guess no less than 35k, probably closer to 45.
Edit: labor ranges from $120-170 an hour around me, depending on shop.
The hemi is what's throwing me off, I know what they cost to buy, but no idea on a rebuild, I assume it's considerably more than a 440.
Either way, awesome build and story, I've been following it from the beginning. Your mother in law(?) still doesn't know right?
