Terry Claunch
72 Dart
The hood hinges on my Dart bow out when I close the hood. I took the hinges off and the pivot point has a lot of slop. I assume this is my problem and does anyone know how to correct this. If I purchase a used set of hinges, I am afraid I will wind up with the same thing. The right-side hinge was bowing out so bad it was rubbing the inside of the fender. Any advice would be appreciated. Thanks
