Help
Dustya_318
San Jose California
360ci with a 727 on it 8 3/4 rear end when driving around 60 mph or so i start to feel a pulsing vibration underneath the car. . . people have told me it could be my driveshaft. . could this be true? and wat can be done about it?? also just last week my tranny started making a whining noise once i hit second gear and it gradually gets louder need to fix fast because i dont have another car to drive at the time do i just need to change fluid or something else. . . POSTED THIS IN WRONG SECTION SORRY
I had an auto that was making a whining noise on me. I changed the fluid and filter and it stoped. So it could be a pluged up filter mabby. The vibration could be your driv shaft out of balence or your tires? But I don't know for sure.
I'll lay my quarter bet on torque converter trouble.
Sounds like a Torque Converter Sprag or Fin Failure...Bearing also could be coming apart in it....ALSO could be the Rings on the Pump Support and Leaking inside releaving pressure internally...
This COULD also be part of your vibration...What Converter and Flex plate do you have on it?
SS
