[SOLD] ‘67 Steering Column: manual, column shift, linkage
JD Erisman
Alaska
This is a ‘67 A body manual steering, column shift column with shifter and all the linkage. This is correct for a ‘67 but will work in a ‘68 and ‘69. Norms Speed Shop built this two years ago, I put a little under 1,000 miles on it. It is straight, turns and spins great, not a problem with it. The plastic bearing at the bottom of the shaft was overheated by the headers and the locking tab slightly melted, it still functions perfect, just looks weird; see pictures. My tachometer mount marred the paint a little otherwise appearance is great; see pictures. The shifter light works. Comes with the coupler mounted and greased. All of the shift levers need cleaning but are straight and there is nothing wrong with them. The turn signal switch functions.
$250 shipped anywhere in the USA from 99611.
A body. I think any A body will cross over. I don’t know what particular model it came out of. I bought it from Norms and he didn’t state anything other than A body.
