moper
73 340 engine, complete minus carb and manifolds. This has been completely stripped to bare block and freshened with many new parts but remains std bore. Crank needed to be turned and is now .010/.010, engine remains factory external balanced. Stock Thermoquad intake. New parts: cam bearings, brass freeze plugs, block hardware, oil pump drive bushing, oil pump and pickup, rod and main bearings, rings, gaskets, camshaft, timing set, lifters, valve springs, valve seals, spring retainers and locks, thermostat, water pump, fuel pump, distributor and ignition parts, exh manifold studs, water temp and oil pressure senders, PCV & breather, and bypass hose. Camshaft and valvetrain are all Comp Cams, cam is the XE256H. Engine has been run on engine stand and camshaft broken in. Distributor has been set up with a typical street curve.This is not 100% all rebuilt but very serviceable, ready to drop in, and still has the capacity for a full rebuild down the road if you want to. Comes with build sheet and all parts on it. I have video of it on the run stand and build pictures. It’s ready for your mild street car or restoration. Will not ship but may deliver for a fee within 300 miles of 06237 after full payment.
The build stamping has at least one character that didn’t stamp well but it reads “_M340 05318068”. Vin stamping is “3B520765”.
Asking $3600
Asking $3600
