Demon 408
“Lot Sale”: New and Used 340 / 360 Engine Parts, 8 3/4 Gears, and various Small Block and A-Body parts - Over 100 parts - See detailed parts list below - Click link HERE to see pictures.
Price: Asking $1400.00 for everything - Parts valued at over $3,000.00 - I WILL NOT sell parts separately - Reasonable offers will be considered.
Payment Method Accepted: Cash
Parts Location: Williamsburg, Virginia
Local Pickup Only
Description: This is an all or nothing Lot Sale. I’ve priced this sale low enough that you could very easily make your money back and still have a “free” 340 Block (Std. Bore), X-Heads, and Steel Crank. Send me a PM if you have questions.
Used 340/360 Engine Parts
340 Block & Main Caps/Bolts - 1969 - LM23P9B239710 - Std 4.04" Bore
340 X-Heads - Casting#; 2531894-A, 2531894-E
340 / 360 Mopar M1 Single Plane Intake - PN# 4452893
340 Crank - Forged; Casting# 2532457; Std. size journals
340 / 318 Crank - Forged; Casting# 2128869; 0.010 under sized journals
340 Crank - Cast; Casting# 3462387; Std. size journals
360 Crank with balancer - Cast; Casting# 3418640; Std. size journals
340 Pistons/Rods, Set of 8 - TRW Std. Pistons PN# L-2322 - Mopar Rods PN# 2899496
360 Pistons/Rods, Set of 8 - KB Std. Silv-O-Lite Pistons PN# 509 - Mopar Rods PN# 53005798
340 Exhaust Manifold; Drivers Side
340 Exhaust Manifold; Passenger Side - Small crack and small hole (see pics)
340 Exhaust Manifold Bolt Set (Original)
340 / 360 Stamp Steel Rockers, Shafts and Push Rods
340 / 360 Stamped Steel Rockers and Shafts
360 (LA) Oil Pan - A-Body
New, NOS or Reconditioned Parts
Battery Cables, Set - A- Body 1970-76
Battery Hold Down Kit A-Body
Cam Bearings, Mopar, 340, 2 each
Cam Bearings, Set - Manley - 340
Crane Hydraulic Lifters, Set of 16 - Mopar Small Blk
Dist. Advance Weight Springs
Door Hinge Pin 1967-74 A-Body
Door Jamb Switch, 2 each 1969-73 A-Body
Ford Air Cleaner Lid/Filter
Head Bolts - Small Blk
Holley Flange Gasket PN# 108-14
Holley Gaskets Set, Fuel bowl and Metering block PN# 108-200
Holley Power Valve Check Ball Kit PN# 125-500
Holley Power Valve PN# 125-25
Holley Power Valve PN# 125-35
Holley Power Valve PN# 125-45
Holley Pump Discharge Nozzle PN# 121-25
Holley Pump Discharge Nozzle PN# 121-28
Holley Pump Discharge Nozzle PN# 121-35
Holley Quick Change Kit for Vacuum Secondary PN# 20-59
Holley Renew Kit - PN# 37-1184
Holley Vacuum Secondary Diaphragm PN# 135-3
Holley Vacuum Secondary Spring Kit PN# 20-13
Horn Button Switch - PN# 2771534
Main Bearings, Set - STD - Manley - 340
Mopar Fuel Filter
Pinion Shims, various sizes
Piston Ring Set, Manley, 4.04 Bore, 1/16, 1/32
Piston Ring Set, TRW, Moly, 4.04 Bore, 1/16, 1/33
Rear Main Seals
Rods - Reconditioned Sm Blk - Set of 8 - 2899496
Rod Bearings, Set - .010 under - Manley - 340
Rod Bearings, Set - STD. - Manley - 340
Stainless Steel Door Lock Ferrules 1967-73 A-Body
Thermostat 195 Degree
Thermostat Housing Kit
Timing Chain Gear Set, Double Roller (1 of 2)
Timing Chain Gear Set, Double Roller (2 of 2)
Trunk Lid "cut out" Spoiler Template - 1970-74 A-body
Valve Spring Retainers (3 sets of 16)
Valve Stem Seals (intake and exhaust)
Used Misc Parts
8 3/4 Center Section; 741 Case; Sure Grip, 3:23 Gears, 7290 Yoke
Carter Fuel Pump; 3/8" NPT Inlet and Outlet; 7.0 to 8.0 PSI - PN# M6270
Edelbrock 600 CFM Carb; Square Bore; Electric Choke - PN# M6270
Aluminum Bell Housing for Over-drive trans - 3743859
Holley 725 CFM Carb; Vac Secondary; Square Bore - List# 4118 S
Brake Drums and Backing Plates 11 inch
Driveshaft - Demon with 8 3/4 and 833 4-speed, 7259 front u-joint and 7290 rear u-joint
Headers, Small Blk A-Body; Holes drilled for Dyno EGT probes - Summit PN# SUM-G9040
Manual Steering Box - Small Sector Shaft
Power Steering Box with high pressure hose, Pitman arm and Steering Coupler - Small Sector Shaft
Right Angle Oil Filter Adaptor, Aluminum - Sm Blk
Demon Tail Light Housing, Driver Side (Left)
Ring & Pinion 3.23 Gears for 489 - 29 Spline
Bell Housing Cover
Hurst Shifter & 2 shift knobs - PN# 4106
KYB Shocks - 2ea. KG551 (rear), 2ea. KG 4509 (front)
Windage Tray - Small Blk
Mini Starter - Chrysler/Denso
Parking Brake Cables and Handle
Saginaw Power Steering Pump with brackets for Small Blk
Timing Chain Cover - Sm Blk - Aluminum
Alternator - Square back
Bucket Seat Tracks (modified)
Headlight Bezel, Driver Side - 71 Dart/Demon
Steering Column Parts - Auto on column
Alt Pulley 2-groove
Crank Pulley 3-groove
Accelerator Cable - A-Body Small Blk
Battery Box - 72 Demon
Carter Fuel Pump Parts; 1/4 NPT Inlet and Outlet; 5.5 to 6.5 PSI - PN# M6902
Door Hinges - A-Body 72 Demon
Fan Clutch - Mopar Small Blk
Heater Controls - A-Body 1972
Motor Mounts - 360 Engine in 1973-76 K-frame
Rear Interior Panel Chrome Trim - Demon, Duster 1971 - 72
Tie Rod Sleeves
Demon Tail Light Lens, Driver Side (Left)
Demon Tail Light Lens, Pass Side (Right) 1 of 2
Demon Tail Light Lens, Pass Side (Right) 2 of 2
Accel Super Coil
Dash Pad
Edelbrock Air Cleaner with K&N filter, 14 inch dia. With 1.25 drop base
Front Lap Seat Belts - 1972 Demon
Glove Box Door - Includes latch and hinge
Grant Steering Wheel with adaptor
Interior Panels - Front and rear
Lower Shock Mounts - 7.25 Rear
Mirror, Drivers Side - A-Body 72 Demon
Pinion Snubber - 7.25 Rear
Rallye Wheel Trim Rings, 2 each - 14x6
Shifter Chrome Trim
Trans Mount - A-Body 72 Demon
Alternator Brackets - Small Blk
Door Hinge Pin - A-Body 72 Demon
Horn Button - A-Body 72 Demon
Tachometer - Autometer Sport Comp
Valve Spring Tool
Window Cranks, set of 5 - A-Body
Local Pickup Only
Mopar Fuel Filter
Rear Main Seals
Used Misc Parts
Bell Housing Cover
Alt Pulley 2-groove
Tie Rod Sleeves
Accel Super Coil
Dash Pad
Shifter Chrome Trim
Valve Spring Tool
