0-90 ohm sending unit OR 73-10 ohm Gauge
64physhy
Weatherford, TX
I bought a package deal on a set of Autometer Ultra Lite gauges, and it came with the 0-90 ohm (GM) gauge. Ideally, I'd like to trade the gauge for the correct one, but will also buy the correct gauge or a 0-90 sending unit (Somebody used to sell them on here, but I haven't seen them in a while.)
Located in Escondido, CA 92027
Dave
you can buy coverters to change from GM to mopar... as for a different ohm sender it would be the easiest...
also why cant you fix the stocker?
Fix the stock what? The gauge worked when I took it out, I replaced all my gauges with Autometer auto lite gauges. The sending unit works, too (it's almost brand new). The problem is that the autometer fuel gauge is for a GM sending unit, so it shows close to empty when it's full and close to full when it's empty. I plan on putting in a fuel cell and getting rid of the tank anyway, so I can wait and put a GM sender in the cell if I can't find one.
