04 5.7 hemi with 2010 5.7 eagle head question
what head gaskets are you going to use? a .075 is required to get the compression ratio down to a bout 11-1 and with that gasket, you can go fairly large on lift
just the factory gasket im going to run a carb and e85 fuel
This is awesome. I plan on running a forged stroker 392 with the eagle heads on e85. If I recall the compression will be around 12.5:1. I am almost postive you will need a custom cam to make it work. I have a few cam specs laying around some where, but they are based on my stroker and not a stock engine.
