tblotske
how big a cam could I run with this on stock bottom end and any ideas on hp it would put out
x2, im interested in the numbers myselfi would suggest calling a vender that is familiar with that setup maybe inertia or hhp
This is awesome. I plan on running a forged stroker 392 with the eagle heads on e85. If I recall the compression will be around 12.5:1. I am almost postive you will need a custom cam to make it work. I have a few cam specs laying around some where, but they are based on my stroker and not a stock engine.just the factory gasket im going to run a carb and e85 fuel
