dodge71demon
Considering using the 1" drop leaf springs from esco.I'll be using the HDK on my 69 Valiant with a 383.Any body using the ESPO 1" drop GOOD - BAD - UGLY
Is this a factory rear suspensioned car?
Just mount an 1" lowering block between the axle.
If you don't like it you can remove them again.
I wouldn't spend money on new springs for only 1" ride-height change.
Besides, the new springs would probably startout at the same height you're at now before they sag a bit.
That changes the situation a bit
If I were to buy a 1" under spring i'd buy caltrac mono leafs and use their bars.
depend son intended use. looks like he is using a HDK so maybe he wants a street car that handles. don't see that being a strong point of the caltrac set up. a car for the drag strip is a different story..
What is handling?
Bergmann Autocraft has a set they sell that are superbly made, not cheap but should be perfect.
