Dan you can't assume that the guy before ya set this engine up the proper way as far as having No.1 at 10 oclock on the distributor. By pulling the oil pump drive shaft which has the cam to dissy gear on it you can change the location of No.1 by just remeshing the gear a couple teeth one way or the other.
Take Longgones advise and first put No.1 at TDC at the end of it compression stroke and go from there.
Terry
Ya,, terry I might need ya to have a look atmine before I start it (which is very soon ) I have 1 cyl at tdc and the rotor is pointing at the #6 wire in the pic above
Turn the motor one more revolution and see where the distributor is then.
Terry
My dad made this saying about chrysler V8 small and big block dist cap wireing. To reduce wiring confuseion. “the small block has the dist in the wrong place, in the back of the engine. BUT the shaft rotates the right way clockwise. The big block has the dist in the right place, in the front of the engine BUT the shaft rotates the wrong direction counterclockwise. Both wire #5 and #7 on both ALL ways have #5 before #7 on the cap AND block. And most / some stock V8s have the fireing order cast in to the intake manifold. AND: DO plug the vent with JB-weld. Keeps the moursture out.
