just wanted to let you guys knows just for the hell of it incase some one is looking for a cheap fix or to see if it helps
i added a one inch plastic carb spacer from mr gasket
it did away with a good junk of my low end stumble say 1300 to 1800 rpm
cars a 10/5 to one 340
500 lift cam
750 eddy
mp elc ing
stock x heads
steel intake
its a STOCK 340 with STOCK hp manifolds like the day it left Chrysler
340hp gts dart so any thing stock on that is what im running besides whats listed
it all so helped with the heat soak issue i was having
i know this info is worth noting to most but i was just throwing out what i learned to maybe help some one else out
chubs
500 lift cam
750 eddy
mp elc ing
stock x heads
steel intake
chubs
