[SOLD] 10" Brake Backing Plates
wish4hemi
10" rear brake backing plates removed from a big bolt pattern 8 3/4 rear end. Most of the hardware is still present, although new hardware kits are readily available, cheap, and recommended. Check out RockAuto part numbers H7129 ($5.10), H2528 ($6.08), and H2529 ($6.89).
Shoes are junk and will be discarded for shipping.
$80 shipped to the lower 48
Quick question so these are b body backing plates that can be used with 5 on 4.5 axles?
That is correct. They were removed from a 1970 B-body but can be used on any 8 3/4 that is going to use big bolt pattern (5x4.5) axles.
Do you have the E-Brake part that goes in the middle there? Thanks.
