10 inch brake drums any diferences
Snake
Mopar Nut
Belleville Canada
Nothing seams to be going my way on this Dart.I have 10 inch drums on the front thing is there not the same they dont match.Someone must of change one at some time.Right now I could care less that they look different but does it mater the shoe size is the same.kind of feeling pisssssed right now.
No problem at all Snake. The original drum must have been scored too deeply to machine out, so the only thing to do is replace it.
Carry on, sir!
:D
my original drums looked like that...one side you could pull off without messing with the bearing and the other side you had to take the bearing out. They still worked about as good as they possibly could have though. Of course, I replaced them with a disk setup.
