Dusto
Member
i was wondering if 10" wide rims would fit under my 74 duster? with out doing any tubing? does any one know?
yea i have a b body 8 3/4 so i guess ill stick with the 8" wide may see if i can pick up a set of 10" just to see how they look, i didnt know that the b body 8 3/4 is 3 inches wider....so i can buy a kit witch moves the spring in that may help but thanks so you dont have a b body rear under the Dart?
From what car model did you take your b body 8 3/4 ? and what else can fit me ? As far i know sizes are going to depend of the building year ! Thanks in advance !
je je je thanks man, but i'm from venezuela and that could be imposible.The pre-71 B-body rear ends are narrower than the 71 and later ones. Any pre-71 rear would fit. If you'd like to buy one and are close to Michigan, I have one from a 69 Charger I will sell you for $75.00. It includes the housing, 3:23 center section and the drums. The backing plates and the brake hardware are missing. Let me know if you'd like any more details, Geof
I found a 75 dodge Coronet complete differential what do you think ? Thanks !The pre-71 B-body rear ends are narrower than the 71 and later ones. Any pre-71 rear would fit. If you'd like to buy one and are close to Michigan, I have one from a 69 Charger I will sell you for $75.00. It includes the housing, 3:23 center section and the drums. The backing plates and the brake hardware are missing. Let me know if you'd like any more details, Geof
I found a 75 Dodge Coronet complete differential ! what do you think ? Could it fit and look nice ?
