12" Brake Parts
bwhitejr
Missouri City, Texas
The 8 3/4" rearend I bought has 2 1/2" brake shoes and 12" drums, but most of the brake parts are missing. Where can I get replacement parts? Like spreader bars, emergency brake adjusting mechanisms and such. NAPA, Oreilly?
bwhitejr
bwhitejr
I'm guessing you have 11" x 2-1/2" brakes and not 12". I'm not sure they made a 12" brake.
Local stores should have wheel cylinders and brake shoes. They may
have everything you need. If not Year One has
spring kits (BG536) and self adjusting kits (BG554 LH) & (BG555 RH)
You will need to find spreader bars and the parking brake levers at the boneyard, but everything else you will need is available from rockauto.com. They have a listing for the levers, but either the picture is wrong or the part is wrong. Hope this helps.
im with tony. i don't believe they came with 12" brakes. i had a whole steup of 11" brakes for an 8 3/4 i sold to my buddy and i got most of the missing stuff at the junkyard. you should be able to get the self adjuster kits, hardware kits, shoes, and wheel cylinders locally. its all here http://www.raybestos.com/catalog/consumer/icat.cgi
take the part #'s in and order.
