wish4hemi
120 amp alternator removed from a running Mopar small block. It probably has 500 miles on it and was new when purchased, not remanufactured. This is the external regulator version so you can keep your factory regulator and the associated wiring. It works with factory brackets as well. Super easy to install.
This was on a 360 engine with iron heads, an electric fuel pump, electric fan, a custom ignition system, and EFI. I would highly recommend doing the MAD electrical bypass for this alternator: Catalog
$95 shipped to the lower 48. I prefer PayPal but can do Venmo or a cashier's check as well.
