[SOLD] 13 MOPAR engines 50's, 60's & 70's, 331 HEMI, also some trans
6pack71bee
dothan alabama
Rating - 96.4%
27   1   0
HERE ARE 13 DODGE/PLYMOUTH ENGINES AND SOME TRANSMISSIONS THAT I HAVE FOR SALE. WILL SELL INDIVIDUALLY OR WILL MAKE A PACKAGE DEAL ON ALL REMAINING ENGINES. POSSIBLE TRADE ON 1 or ALL. these are located in Dothan, Al and i prefer not to ship motors unless you make all the arrangements and have picked up at my shop. PM for more info or trade list. thanks, steve
1950'S 331 HEMI w/TRANS & BELLHOUSING, GREAT FOR RAT ROD, $400
1965 BIG BLOCK 383, STEEL CRANK, 4BBL MOTOR, DISASSEMBLED, NO CARB, $300
1966 BIG BLOCK 383, STEEL CRANK, 4BBL MOTOR, SHORT BLOCK W/ CRANK, PISTONS, RODS, BALANCER $200
1966 & 67 SMALL BLOCK 273 HI PO MOTORS, 4BBL w/ ADJUSTABLE ROCKERS, NO CARBS or ALT'S, WILL NOT TURN OVER $350 PAIR
1968 BIG BLOCK 383 MAGNUM, STEEL CRANK, 4BBL MOTOR, HAS A/C, NO CARB, EX. MANIFOLDS or ALTERNATOR, LOCKED UP $350
1974 BIG BLOCK 400, COMPLETE MOTOR & 727 TRANSMISSION. w/A/C, ALT, ETC, WAS RUNNING WHEN PULLED, $425 or $325 w/o trans
1976 BIG BLOCK 400 BLOCK W/ CAST CRANK, MAIN CAPS, BALANCER, W-PUMP HOUSING & OIL PUMP $150
1976 BIG BLOCK 440, CAST CRANK, BORED .030, DISASSEMBLED BUT MOSTLY COMPLETE, 4BBL INTAKE, NO CARB, $225
1977 BIG BLOCK 440, CAST CRANK, THERMOQUAD 4BBL, COMPLETE MINUS EX. MANIFOLDS, LOCKED UP, $300
1989 318 MAGNUM, PARTIALLY DISASSEMBLED, $200
PLUS 2 OTHER 360 ENGINES (one is a 71 but will have to check year on the other one)
ALSO HAVE SOME MOPAR TRANSMISSIONS:
SMALL BLOCK 727's FOR REBUILDING, $100 EA
SMALL BLOCK HEAVY DUTY RV 727 w/ SHORT TAIL SHAFT, $100
BIG BLOCK HEAVY DUTY RV 727 w/ SHORT TAIL SHAFT, $125
SMALL BLOCK 904 FOR PARTS $50
SLANT 6 AUTOMATICS, $75 EA
B & E BODY 3 SPEED MANUAL w/SHIFTER AND BELLHOUSING, $100
A BODY NON O/D 4 SPEED (i think it is a 70 model) $450
331 HEMI has extended bellhousing so adapter cannot be used. please PM for questions or list of items i may trade for
Bump, 331 hemi, 4 speed a body trans, BB 727 trans have sold, please PM me with any questions or for a list of items i may trade for. can accept credit card or paypal (plus 3% fee), postal M/O or cash in person. may trade for 1 or all together!
Too bad you're so far away. If you weren't I'd buy the whole lot. I'd be like a kid in a candy store. :) :) :)
