[SOLD] 130 tooth flywheel neutral balanced
moparfan68
virginia
heres a used 130 tooth flywheel im never gonna use i bought it from a member here about 10 years ago and i havnt used it yet so its time to go. $100.00 shipped to lower 48
Hi. Will this work with a 360 and 833?
Only if your 360 has been internaly balanced. If not You will need a 360 specific flywheel with a balance weight on it. Even cast crank 340 and 360 had different flywheels weights.
And I should have also mentioned that yes this flywheel could be used on a 360 but you must get the 360 specific weight and have a machine shop drill the flywheel in a very specific location so the weight can be bolted to flywheel. Sorry for any confusion.
