Longgone
John/68 Barracuda & Dart
This is not about my B`cuda, rather my 2003 Dakota. A couple weeks ago the engine light came on. All of the major systems (oil pressure, charging, temp.) were okay so I didn`t freak over it too much, but it bothered me so I decided to take it to the dealer and have them diagnose it. I took a look over things myself and didn`t see anything obvious and most everything is under warranty still. I dropped it off and got a call later in the day. The mechanic hooked it up and it showed a code in the gas evaporator recovery system. The truck has only 16K miles on it, but the warranty had run out on everything but the drivetrain. The service writer said it would be $188.00 dollars to fix the problem.(The gas cap was replaced about 6 months ago.) I declined the repair and picked up the truck. A $52.00 charge and my light was still on. A good look under the hood revealed two cracked vacuum lines at the charcoal canister. I replaced them with $2.80 worth of vacuum line and NO MORE LIGHT!
