15" Slot Wheels
rosco426
Active Member
Oz
Hi guys,
Question from down under, chasing a set of 15" slot wheels that best match the rim attached below. Unfortunately new engine requires more traction and I can't seem to find a drag radial in a 14 to suit my needs so its an excuse for biggers wheels and hopefully a little more dish on the rear.
I would be after a 6 or 7" front rims and 8 or 8.5" rim for the rear. Ideally I'd have a 4" backspace for the rear too so I can have a bit of dish as I mentioned above.
They can't be a unilug rim, need to have a push through centre cap and valve coming out through the bean as per the photo.
I'm hoping you guys can help me. I have emailed AKH wheels but I'm sure there are more places that would be able to help that you guys would know of.
Appreciate the help in advance.
Hi guys,
U.S. Mag wheels makes those slots, but I believe that the center cap bolts on from the outside. A friend of mine just bought a set of 15x4 fronts and 15x8 rears in 4" bolt pattern for his dart. They also use a conical seat lug nut instead of a shank type. They aren't unilug either. I'll try to dig up a pic of his car so you can see what they look like.
Thanks for that. Not really what I am after though as I don't want those holes to be visible otherwise I would have already bought a set.
I know Ansen Sprint and Appliance used to make a wheel that would suit, just can't find any.
