I have 16 X 7's on the from of my 65 Cuda. I'm running a 225 50R16. This just clears everthing. The back space is 4.5. This setup comes within a 1/4 of an inch of the front sway bar when fully locked. Full lock in the other direction is clear of everything. This would be the max back space you could run. The thing is if your car is sitting real low, it may rub on the outside fender lip when turned, or will be very close. My car is sitting fairly low, and through the full range of motion it shouln't rub.
