Looking to sell my 37 Plymouth. Haven't been able to touch it for two years. I was setting it up for a big block 4 spd combo as you can see. I have two 38 Plymouth front clips(I don't have a 37 clip), and six rear fenders. Two sets are steel one set is glass. Custom made running boards, I was going to run it without. Door handles have been shaved as have the hinges. Comes with all the electronics for the doors and trunk. I have all the garnish moldings for the inside. Comes with a fresh 69 383 with a 284 484 cam in it, the long rams, and a matching set of 450 hollys.
The 4 spd is a 833 od with a new shifter and handle. I have a wiring kit and stock and LED flush mount lights. Car has Camaro front stub with Fatman parts,and a Morrison rear frame. 4 wheel disks and a narrowed 8 3/4 with 3.55 sure grip, still need the get axels mad( has stock cut to fit) Wheels are ET gasser, 16x12 rear and 15x5 on the front. Lots of parts go with it. $11,000 you get it all. I have waaaay more then that in it. in Strasburg CO.
