terzmo
1949 Ford F1 modified but all Ford drive line. 351 Cleveland 2bbl and 4 speed. Converted to 12 volt system. Modified dash as speedometer and tach are installed, look like old school and other gauges mounted under the dash. Bucket seats and pistol grip shifter. Bucket seats. Power assisted drum brakes that stop as well as disc. New Cooper tires..295/50 with 10 inch wheels on rear...215/60 on front with 8 inch wheels. Custom side exhaust sounds deep and mellow. Aftermarket bed with custom bed floor and strips. Running boards both sides. Vega tail lights. No whine out of tranny or rear. Motor has plenty of power. Vinyl graphics can be removed easily if wanted. Body is straight and paint looks decent. It is a driver and has some small chips. Underside is clean and solid. It runs down the road as well as when made 72 years ago with stock front and rear suspension. It is not a sports car. I may of forgot some other improvements. Located outside Buffalo NY. $19,500 or best reasonable offer. Lowballs are rejected.
