1960 Dodge Seneca Wagon
jjkeenan
Active Member
DE
Rating - 0%
0   0   0
Looking for a gas tank sender for a 1960 Dodge Dart Seneca wagon, does not have to work well as long as it is complete, also interested in the push button unit under the dash for the transmission shift. have the oringinal but it sticks TORQUE FLIGHT TRANS R N D 1 2 five button unit. 302 5454875
I have a sender for a '61 Plymouth S.W. I'll have to do some research tonight to see if it's the same.
The tank is in the side between outer fender and inside of rear cargo area. the sender goes in with a O ring and twist ring lock. It goes in the upper side of the tank and the tank fills from the top near the drivers side of the car at the rear window of the wagon.I expect if the tank mounts the same in the 61 the sender is essentially the same. You can call me at 302 545 4875
It shows the same part number in the book so it should interchange with no problem. PM sent.
I would like to see a picture of your SW. My Dad bought one new in '60. It was what got me started in Mopars.
Thanks
