1962 Plymouth Valiant 4 Door with a 225 Slant 6, with a Holley 2 Barrel with Headers, .436 cam, Fully Rebuilt Engine all Internals Renewed, Head was Updated to a Later One with Hardened Seats so you can Run Unleaded Gas Rebuilt also, Push Button Automatic Transmission Rebuilt Earlier, Rebuilt Rear Springs, Rear End/Axel Replaced with 35,000 mi one out of a 1976 Duster, Brakes Rebuilt From the Same Front and Rear, New Front Shocks and New Rear Air Shocks, Ball Joints, Bearings, Drums, Idler, Pitman Arms, Tie Rods, Drive Shaft Rebuilt, Starter, Alternator, New Electronic Ignition, Regulator, ECI Unit, Wires, Cap Etc., Master Cylinder is Updated with a Dual Type Master, Custom Blue Paint with Multi Color Metal Flake & Pearl Done by Local Body Shop, Factory Rally Rims with Newer Tires, New Carpet. Manual Brakes, and Steering. Car Needs Some Completion, Here is what is Needed to Complete; Radio is Present But Needs to be Installed, Headliner is present but needs to be installed, Arm Rests are Present but Needs to be Installed, Seat Belts need to be Connected, some body trim is present but needs to be installed, Kick down linkage is Present But Needs to be Installed, Front End Alignment, Rear Package Shelf, Gauges Work but I do not know how accurate they are. Car was purchaced from 2nd owner and has 83,000 original miles, was Pink and now is Blue. Needs finishing touches. Car is in Very nice mostly restored condition. 20 plus MPG. Car Runs and Drives and I do drive it locally. Car must be picked up in Milwaukee WI 53214. I will not ship but will assist. Cash at pick up or Bank check must be sent in advance and cleared before pick up. Any Questions Call Pete @ 414-349-2547. Car must be picked up with in West Allis, WI 53214 (Milwaukee). Serious inquires Please. To see pictures go to e-bay item number 380159587106. Thanks, Pete. $3800.00 OBO.
