71scamp78
64 Plymouth Belvedere with a 6.4 Hemi and rebuilt 727 with a new Hughes 2400 stall converter. Has new rear leaf ss leaf springs, front and rear hangers. New axles with green bearings as well as new Yukon sure grip with 3.90 gear. New KYB shocks on all 4 corners. New Aeromotive Stealth fuel injection tank. Has new manual steering box, new pitman arm, new idler arm and new inner and outer tie rods. Will need upper and lower ball and upper and lower control arm bushings. Drive train is great and runs great will haul ***. Body is pretty solid overall Has some filler over rear wheel wells, frame is great and trunk is solid original. Needs floor pan work on drivers side. Has good carpet and also has some super stock seats with aluminum brackets from Gary Ball. Have headliner needs installed. Needs some interior work like door seals and panels. Drive as is or fix her up. I have a lot of money in the drive train. Located in Terre Haute , Indiana. May trade for a pre 73 Duster or sale for 24k firm
