tubbedamx
Location Boise, Idaho
1963 Chevy II Wagon Asking $4,500.00 obo
Located in Boise, Idaho
Can deliver within a 1 day drive from Boise. For example Seattle, Portland, Reno, Sacramento, Salt Lake City.
Or Ship via Transport Truck.
Great muscle car, sleeper, drag car or family hotrod
Body and glass are in great shape. Drivers quarter has a small amount of damage from the lower body line and down. Passenger side quarter is a silver dollar size spot in the very lower quarter.
Have ALL trim: Headlights, tail lights, hood/tailgate and fender trim.
Car starts and runs with no cooling or charging issues. Great Muscle car sound. I have driven the car a couple of miles and its great. I have not touched the steering or suspension however it looks good.
List of New Parts
Clear Idaho Title in My Name
FUEL SYSTEM:
Gas tank with sump and drain
3/8 sending unit (Not being used)
½ fuel line
Holley blue fuel pump
Barry Grant fuel pressure regulator
Fuel pressure gauge
Black -6an fuel line to carburetor kit
Suspension 4 new shocks
Traction bars (Early Nova specific)
New driveline
New yoke
New U-joints
8.2 10-bolt rear. 3:36 rear gear ratio
5 on 4 ¾ Bolt Pattern (Brakes and Axles from a 65 Chevy II)
15x7 Chevy rally rims, date coded to 1971 Chevelle
Two new rear tires
Brakes OEM drum brake duel reservoir master cylinder
New wheel cylinders
New shoes
Drum brake hardware kit
Brake Fluid
New rear rubber brake line w/clips
New front: left and right rubber brake line w/clips
New brake drums
Engine
Rebuilt 400sbc, 882 1.94 heads, 9:1compression @350hp
New nova V8 oil pan and pickup tube
Hooker Fenderwell 1 ¾ headers with 3inch collectors
Headers (Ceramic Coated Turbine Color)
New inner fender panels
New dual 3 inch exhaust with Terminator mufflers
Exhaust painted black w/ 1500degree paint
New motor mounts with safety strap
Edelbrock Torker aluminum 4barrel Intake
Holley 750 carburetor
New Edelbrock performer rpm hydraulic cam/lifters 234/244 @ .050
New 3 pass radiator (From a 65 283 Nova)
New radiator and heater hoses
New cooling fan
New short water pump
15x4 Edelbrock air cleaner assembly
Aluminum crank and water pump pulleys
New early Nova low mount alternator kit www.chevy2only.com
Transmission
Rebuilt th350 transmission with kick-down cable
Hughes 2500 stall converter
Hurst Quarterstick ratchet shifter (Standard shift pattern)
New Hurst shifter cable
New transmission cooler
-8an transmission cooler lines
Accessories New Autometer gauges (Tachometer, Water Temp, Oil psi and Battery volts)
Heater Core
Electrical
New AC Delco battery
NHRA approved battery tie down
New battery cables
New summit racing blueprinted HEI
New Ignition Switch (Correct for HEI) with keys
Neutral Safety Circuit
Engine and Chassis are grounded throughout to battery
Lots more pics available through PM from my email....
List of New Parts
FUEL SYSTEM:
½ fuel line
Fuel pressure gauge
New driveline
New yoke
New U-joints
Two new rear tires
New wheel cylinders
New shoes
Brake Fluid
New brake drums
Engine
New cooling fan
Transmission
Heater Core
Electrical
New battery cables
