[FOR SALE] 1963 Plymouth Valaint Super Street Or Strip
MOPAR67
Rating - 0%
0   0   0
1963 Plymouth Valiant 2Dr Super Street Or strip,Built 68 440,Steel Crank,MP HYD 292/509 Cam,Mild Ported 906 Heads,Electronic Ignition,MSD 6AL Box,Edelbrock 2-4's Intake With 2 AFB Webber 600 Carbs,Fender Well Headers With Full 3 Inch Exhaust Front To Back And Flomasters,Aluminum Radiator,Built 727 With 3000 Hughes Converter,Frame Tied,8 3/4 With 742 Case And 391 Posi Lock, Gasser Stance,Solid Body And Underside,Needs Very Little TLC,All Lights Work,Turn Key And Runs Super Strong, $8500 o.b.o, Trade For Low Miles Jeep Wrangler,Mopar Street Rod.
What kind of times does it run at the track? After re reading his ad, I’d say it would be hard pressed to run more than a mid to high eleven. Kim
Did you build the car?
How long did you own it for?
The Car Was Built By Two Guys In Wisconsin,A Lot Of History To It.Was Stored Most Of The Time.I Did Do Some Work To It,To Make It 100% Street Ready.I'v Only Own It About 5 Months.If You Want More Info,Check (Detroit craiglist) And Call Or pm Me.
