[WANTED] 1963 tranny A-903 30 tooth gear with housing
Fitzgerald Grant
Florida
Rating - 0%
0   0   0
Hi need gear with housing for a 1963 Mopar a-903 tranny..already tried a newer A-903 gear but it won’t work
You need the complete speedo cable with end for gear. see your PM
The old (pre '66) speedometer gears only went up to 21 teeth. Higher ratios had to use an adapter.
