[FOR SALE] 1963 Valiant
FU64RY
Lewisberry Pa.
Rating - 0%
0   0   0
Decent turn key driver 120k miles
4 door sedan 170 PB.
Just completed lots of mechanical maintnance.
New complete brakes including shoes cylinders spring kits hoses and new lines all the way around including the rear center one.
New drums with all right hand studs.
New carpet, very good tires. New battery
Minor rust issues that were addressed by the previous owner..Who probably was not a body man.
Park cable is broken at the under side of the dash I have a good one that goes with the car.
The square exhaust gasket between the intake and the exhaust was leaking. A new one has been put on and the addition of a new intake to head gasket was installed at the same time.
Trans was serviced and a new filter was installed, oil change with new Napa Gold filter. Antifreeze to -20. Greased all of the upper and lower and tie rod ends look really good. Probably changed from when it was new.
Interior is decent Head liner and visors are very good.
New Pa state inspection.
Send a PM if you need any questions answered.
Steve
$2375
