1964/65 Barracuda pictures...
moper
eastern CT
On the 64-65 Barracudas- I’m looking for a couple of clear close ups of the areas where the quarter panel and rear bumper filler panels join, from just below the tail light cutout to the lowest edge. Preferably before the sealer or painting so I can clearly see the joints and how they did them. Any help is appreciated!
Don't know if this will help but here is the back of my 64
Thanks Brian - It helps, but blowing it up so I can see the areas make it blurry. I appreciate it. Hoping I can find clear close ups of those corners.
Thanks Brian! Are the seams overlapped and then spot welded? Or it there a 90* flange on each panel, and the spot welds are along those flanges? Looks like overlapped... is that the factory steel?
The seams over lap, the valance is laid inside the tail panel then spot welded
If you want to PM me with your email I will try to get you some better pictures, not sure when tonight, tomorrow, when I get a chance.
Brian
Thanks Guys. I think I'm good now. In going back to the car, looks like this would be newly-discovered hit #5...lol. The metal was all a mess, hence it not looking like anything pictured. I managed to get some straightened out and matching the left side with templates. I need to fab up some small patches for what I had to remove but it looks like I'm on the right track. I appreciate all the help!
