[WANTED] 1964-74 A-BODY SHIFTER LINKAGE OPERATING LEVER SET
I bought a rebuilt set from Passon. There was a core charge because he remanufactures them. Worked great for me.
Oops. Now that I reread this, I bought 2 rebuilt sidecover gear selector shafts from him. The machined flats and 5/16"-24 threads must be in good shape or you'll have problems.
But you can check with Passon for the levers.
That 3-4 rod may give you trouble does not look like its made correct.
I see what hou are referring to. I just picked up some rods from a member here I need the brackets to connect the rods to tranny. But I just remembered I have an A230 that may use the same brackets ? Hopping they are all the same . Thoughts?
