[FOR SALE] 1964 Dodge Dart GT Convertible $12,850
Smcomanche
Denver
J8GXSekWvoCsdVLu7
1964 Dodge Dart GT Convertible for Sale $12,500 OBO
For sale is my 1964 Dodge Dart GT Convertible. I bought the car to work on with my daughters. It was a great time, and my kids now have the passion for cars I hoped they would have. Alas, it is time to move on to another project. I would be willing to trade for a 4wd camping vehicle, as my kids love to go camping. The car is not a complete restoration and has normal dings and scratches. It is a great daily driver. My primary focus was to make it drivable and safe! The Dart gets a lot of attention and generates many smiles. It also has good acceleration, and sounds amazing with the Hooker headers and dual exhaust with X-pipe My next steps for the car were to add an MSD ignition, TorqueStorm supercharger, fuel injection, and a 8 1/4 , or 8 ¾ or Ford 8.8 rear end, and front discs. The car is awesome the way it is and is ready for upgrades as you wish. I also have most of the OEM parts, and several items I did not get around to installing. These include the original chrome body trim, Transgo shift kit, original intake/exhaust manifold and 1904 carburetor. I also have the service manual and The Chrysler TorqueFlight A-904 & A-727 Transmission: How to Rebuild manual.
Engine and Transmission Specification’s and upgrades.
Engine Rebuilt by Soneff’s Master Garage in Denver, CO
A904 Torqueflight Transmission 3 speed (2000 rpm at 65 mpg, great for cruising)
Bore size +.140” – 3.4405” finish for moly ring
Crankshaft size- .020”/.020”
Oil clearance rods- .0012” mains .0019”
Top ring gap- .020” 2nd ring gaps .014”
Milled .015” off block and cylinder head total .030”
Valve sizes intake 1.620” exhaust 1.362”
Spring pressure (COMP Cams) 80lbs seat 200lbs open
AR rod both torque 50ftlbs
Main torque 85ftlbs
Cyl. head torque 80ft lbs.
Valve lash .010” int. .012” exhaust ( COMP Cam )
Hardened valve seats
Head port and polish
Valve grind
Fel-Pro Intake Manifold Gaskets
Hooker Super Competition Headers 5602HKR – true dual exhaust
PerTronix Ignitor II Solid State Ignition System 91361A
PerTronix Flame Thrower II Ignition Coils 45111
Holley 390 4bbl Carb. Elect. Choke, Vacuum Secondaries
Offenhauser Single Quad Intake 5270LK
Torqueflite 904 1962-67 Rebuilt High stall 10-3/4” converter – 1.55” pilot
CompCam 264 220/220@ 0.05”, 264/264 adv, 0.44/0.44lift, 110 lobe separation
New Rods
Bearings
Exhaust seats
High flow oil pump, opened oil passages
New freeze plugs
New pistons
20 overbore
Opened up behind the valves
8/1 compression ratio (measured)
Other Upgrades:
American Autowire Dash and Engine Wiring
Electric Fans
Chrome Champion Radiator
Summit Racing Large capacity, aluminum transmission oil pan
Holley Electric Fuel Pump
-AN SS Fuel Return Line to prevent vapor lock. Ready for fuel injection.
Speedhut GPS tachometer
Upgraded Original full current amp meter to safer volt meter
Single pot master cylinder replaced with dual pot for safety
Rear seat belts for safety
Wideband O2 sensor with dual exhaust X pipe
Blue tooth stereo mounted in glove box
Subwoofer (slim, under passenger seat)
New sun visors
Freshly painted dash and engine bay
Summit Racing Chrome Alternator with internal voltage regulator (great upgrade over original mechanical regulator)
Powermaster PowerMax Starter 9300 (mini starter)
Lokar Kickdown cable
Holley Quick change vacuum secondary kit
-AN SS braided fuel lines and transmission cooling lines
New spark plug wires and plugs
SEI Titanium Exhaust Wrap
New gas tank
Drive shaft rebuilt and balanced
Front suspension professionally overhauled (4 new ball joints, 4 new tie rods, 2 tie rods end sleeves, 6 control arm bushings, pittman idle arm
New fuel sending unit
Wheel studs replace to right hand thread
New transmission mount
New starter relay, and ignition switch
New cancel cams and turn signal switch
New windshield gasket and chrome lockstrip
New hood seals and bumpers
Auber Multifunctional gauge (programmable thermostat for electric fans, programmable, temperature display in dash and in glove box)
A1 Cardone Water Pump
LED headlights (The halogens were dismal, and the red running lights are dope!)
Red LED strip courtesy lights
Red LED Dash lights
All receipts and wiring diagram come with car in a binder. I am a Mechanical Engineer and am a bit anal retentive about these things! I worked for Chrysler from 1999 to 2007 and love Mopar's, but maybe it is time for a Jeep?
Link to Photo Album with more photos.
Sure thing. I will get them this weekend. Just so happens I will be in MI in a few weeks, but not with the Dart.
We are still under a lockdown till the 28th. But they just opened up some industries and everyone has gone wild. Just make sure you have a mask as most places will not let you in without them. Have a safe trip.
I tried to PM but your inbox is full. PM your email and I can share the inspection/appraisal with you.
