well here we go ,got all wiring done ,new elc fuel pump with return line to tank,removed fuel sender drilled 5/16 hole in it sodderd a 5/16 brake line in for return fuel easy and cheap......then i jb weld it in and out side for more strieght ......chared the battery hit the key and it runs. any one have a good fuel rail this one leaks at fuel line inlet where it goes to the rail ....must have got damaged when they pulled engine...if you have one pm me thank you .....bonehead :read2: 8)
