1964 Valiant Drive Shaft Length
RustyRatRod
Caput villa stultus
Georgia
Does anyone happen to have or know the drive shaft length on the 64 Plymouth Valiant, 2 door post, A903 3 on the tree and 7.25 rear end? I can measure it one day this week, but I was hoping someone knew so I can do some figgerin. Yes, it's ball and trunnion.
you'll never find it searching "driveshaft"... you need the proper nomenclature...
propeller shaft
53.4 CUJ to CUJ or 56.17 flange to rear CUJ
The Ford drive shaft I have for the T5 measures a tic over 56" to the beginning of the slip yoke close to the U joint. That's good, because that means it's too long. The 9" is longer than the 7.25 and the T5 is longer than the A903, so I got too much shaft. I've been told that a lot.
I went ahead and downloaded it.
I downloaded all of the FSM AND Parts books that are there. Some day mymopar.com will go dark. Think Mr. Rogers dies and his show is no longer on the air. Whoever owns mymopar.com unless they have a contingency plan will pass on and all the data will be gone.
Most likely so. It would be a smart move for Joey to download it all and host it here.
