My turn signal lever is very loose and floppy. The Right hand turn signal works but the left doesn't . What does this repair entail and are parts available for the fix? :banghead:
Many thanks.
ted
Hard to say why the right works and left doesn't - bad connection, broken wire or ??? PM SlantSixDan - he has repopped the turn signal switches and are made by the original supplier of early A turn signal switches or maybe a later switch might work. Good luck! and welcome to the forum!
