y0willy0
Active Member
Hello,
I'm sure this has been covered before, but I'm pretty new here and the search function showed me some relevant threads, but not exactly what I needed to know. I apologize if this has indeed been covered before.
I got a 1964 Valiant V100 out of a barn down in SC, and it has the slant-6 and automatic transmission. It is a two-door, and one of the biggest issues it had was a broken torsion bar on the driver's side.
I bought a grille and couple of torsion bars from another 64 Valiant and they look great. The broken bar came out of the car with no fuss at all, and the new one was no problem, took maybe 20 minutes total.
My first question is this, should I change the other bar as well? Do they need to be a matched pair? The replacements I have are used as well, not new, so I didn't know if the original bar on the passenger side would be "weaker" if that makes sense.
I was going to change out the passenger side, but it is in there SNUG. I was surprised the broken one on the driver's side came out so easily, but because the good one was stuck I just decided to leave it.
Also I was wondering if someone could provide me with the codes on the base of the torsion bars? I want to make sure they match. Are the codes different from left to right? I haven't gotten the caked grease of the one I pulled yet, but I assume (hope) it's the same as the one I put in. It should be since they also came off a car just like mine no?
Is the torsion bar tool a requirement to hammer it out? Channel locks worked great for the other one, but I guess it came out so easy because it was broken and loosened over time? Would soaking the passenger side bar keys in PB blaster help? Any other tricks?
TL;DR
I guess the most important questions I have are 1) should I change the passenger side bar even though it isn't broken to make it a matching set, and 2) can someone give me the torsion bar codes.
Thanks a bunch,
TL;DR
Thanks a bunch,
