barracudajohn
Complete engine, removed from a 1965 Formula S , motor is seized from sitting for many years. Selling as is for parts or rebuild. I did not remove a head to verify domed pistons, if you are serious about buying it and want me to verify that it is a Commando, I will remove a head, I have no reason to believe that it's not a Commando. You get everything including the starter, alternator, carburetor (which is very corroded from sitting) . Air cleaner is very rusty and PO has drilled numerous holes in it. Exhaust manifolds. Must be picked up. Located in ZIP 18052 Whitehall Pa. 2 hours from Carlisle . Asking 650.00. The plug wire separators came unglued and I sold those, the valve covers are rusted off along the edge.
