circlepilot
(The title should be A904)
Well I'm doing it, but not without help. I'm modifying my 1965 A904 by installing a post 1968, non-lock-up, 27 spline input shaft, pump and clutch housing. Why? Torque converter selections. The pre-68 904s input shafts will not allow you to use available, higher stall converters, unless you have one (very expensive) custom made, then you are stuck to just that one, until you have it rebuilt or another one made. Why not just get a 68 or above 904? I don't want to modify the car,(cut a hole) in my 1965 Barracuda, 225. I want to keep the cable shift, shifter and related linkage. I'm "hot rodding" the slant six (with all kinds of bells and whistles) and plan on racing it; I need the higher stall converter, also my crank shaft register has been opened up by my machinist to accommodate the bigger converter. In all of the years working on cars, building engines etc., I have never tore down an automatic transmission. So this is also a learning exercise. I've have gotten guidance, advice and tons of information from members here on the forum and I have manuals. I got my parts off of the net and tonight I started the tear down and insured that my parts are going to work. There is a complete overhaul kit and a shift kit in works also.
