[FOR SALE] 1965 Barracuda
Cantdog
Member
Maine
Rating - 0%
0   0   0
I have a 1965 Barracuda project car for sale. The car was being converted from the original 273 to a 360. The body is in reasonably good shape with a few rust spots showing. It appears to have been white, but repainted a cream color. It includes the following items all of which are new unless otherwise noted:
A partially rebuilt Mopar 360 small block engine(Used)
The original 273 engine with automatic transmission (Used)
A-833 four speed transmission (Used)
Bell housing for A-833 (Used)
Pedal set (Used)
Keisler 8 ¾” rear with 3.54 ratio and 5 x 4 ½” bolt pattern (This is brand new.)
Front disk brake conversion kit
Edelbrock Performer intake manifold
Holley carb (also includes a used one)
Flywheel
Clutch and pressure plate
Heavy duty rear springs
Pertronix billet distributor
WPS Mini-starter
Water pump
Coil
Alternator
Spark plug wires
Goodyear P205/60r/14 tires
Black steel 15 inch wheels
Black P205/70R/14 wheels and tires (Used. Came on car.)
Factory manual
The rotating components for the 360 have all been internally balanced.
The suspension is missing the two torsion bar adjusting bolts.
I also have some special tooling (See pictures):
1. Dolly wheels for moving car body around when the suspension and engine have been removed
2. Dolly for Mopar small block engines
3. Dolly for K-member. This allows you to removed the engine and front suspension from underneath the car.
4. Lifting frame. When used with a n engine hoist, these allows you to pick up the front end of the car so you can drop with K member with the engine and suspension. The engine hoist shown is NOT included.
Lots of miscellaneous items including ARP fasteners too numerous to list.
The car is located in Bethesda, MD. Pickup only. I'd like to get something north of $10K for the whole package, but I will consider any reasonable offer. Please don;t ask be to split it up, at least for now.
