[WANTED] 1965 Carter AFB 4v
enginedoc12
Billings, MT
Looking for a non-spread bore Carter 4v for a 273ci. I believe the code is 4120. That is the only code I can find for the 273 and that is for a 1966. This if for a Commando 273 in the 1965 Cuda. Thanks for your help.
For 1965, a 273HP used either a Carter 3853 for manual transmission or a 3854 for automatics.
I may have an extra in my stash. It would be for the automatic transmission as that's what my Cuda has. It would need a rebuild as it has been sitting for a while. Lemme check the numbers when I get home to confirm. Thx , 65'
Thanks for looking. My chart doesn't even show those numbers.
I have one I took off my 65 barracuda 273 commando with auto, it would need to be gone through sat for a long long time. I will check the numbers on it this weekend in case these other offers don't work out. I am going with a holley
