I have a '65 Dart. NC car with very little rust. It's rolling. No glass or interior front floor pans replaced. Front '73 disc brakes w/ 4.5 pattern and Centerline wheels w/ MT Sportsman tires . Dana 44 rear w/ Comp Plus 3 link tacked in place 10" Centerline w/10" slicks frame tied. Clear 1 lexan kit for all glass. '72 360 + .30 B&B,w/ Eagle forged stroker crank, forged eagle H rods, Probe pistons( 12.5:1), Pro Gram billet 2,3,4 Main caps, Arp main studs,ATI damper, billet underdrive crank pulley, custon Comp flat tappet cam, blueprinted HD melling punp, Moroso 8 qt. pan and pickup and HD oil drive, Austrailian high nickel content new Magnum heads, ported polished w/ extensive bowl work, with roller rockers 1.6 & 1.5 w/ total lifter around 600. Crower laser cut lifters, Mopar valve covers, Mopar race distributor and bronze gear, M1 ported intake, 850 Quick fuel carb, w/ ARP fasteners throughout. Proformance high gear 904 full race trans and 8" converter. PPP billet shifter, Moroso heat sink trans cooler. 8 3/4 w/rear Mancini built 489 case, 4.10 gears moser spool and axles, B body rear drums w/ emer. cables, w/ extra 360 complete and 727. Would prefer to sell whole but as separate $7500.00 motor, $1800 trans convt shifter cooler, $1400 rear, roller $800. Thanks in SE Pennsylvania.
