slimsixpack
New Member
This is a rust free car. Except the gas tank . It is also unmolested. All I did to it was remove the carpet to clean it up a bit. Saved the insulation from the floor it was in good shape. Engine turns over. Only thing missing that I can see is the radio and the carburetor and coil.Has new tires so it could roll. I cleaned all rims and painted. All glass is good except for windshield is cracked. Green tint factory. 273 three on tree. The carb on the engine picture was only to test if I could make it run. Also the coil. Did a compression test on number 1 cylinder had 60 pounds. Probably needs a rebuild.they are not included. I taped the seats to keep down on the foam when I was working on it. Nasty stuff. I fixed all the windows so they would roll up and down. In the summer it's hot in the desert. When I was underneath it the exhaust looked brand new. No brakes. Rolls. If needed I can take more pictures. No title. But one can be had .3500 OBO. This car is located in Las Cruces New mexico .Thank you for looking. Message me and I will get back to you.
