[FOR SALE] 1965 HP 383 engine $500
clementine
Flight risk
Emerald city
1965 Chrysler/Mopar 383 HP engine . Has original hemi oil pan on it. (Pan is dented up a bit tried to capture in pictures. Has correct original 3856S carb. Correct dual point distributer. HP motor. Needs rebuild. Turns freely!! Water pump does not turn freely. Comes with rare/correct HP air cleaner. Great period correct HP motor. Plymouth. Dodge. If you are building a period correct car, these are for you.
Pulled from cop car.
Thanks FABO
1965 Chrysler/Mopar 383 HP engine . Has original hemi oil pan on it. Has correct original 3856S carb. Correct dual point distributer. HP motor. Needs rebuild. Turns freely. Price is ONO/OBO. Comes with rare/correct HP air cleaner. Great period correct HP motor. Plymouth. Dodge. If you are building a period correct car these parts are for you. Pulled from cop car.
Thanks FABO!
Thumbnails not working
Schizen.....I'm tech challenged. I'll get some new pics manana. Thanks for the heads up.
Hey,
I put up some new pictures....turns freely...no grind or chunk. I will try to get out there and pull intake to get more pictures. If you are serious.
