440 Engine, Edelbrock Carburetor, Headers, 727 Transmission, B&M Z-Gate, Shifter, Sub-Frame Connectors, Power Steering, Traction Bars, New Ball-joints and Steering Linkage. I'm not sure what the gear ratio is and I don't know if it's a 8-3/4 rear. For some reason, I remember the previous owner stating it was around a 3:23? Not even sure if that's a Dodge ratio. There's a picture of the rear end below, so you Mopar guys may be able to tell if it is a 8-3/4. This car doesn not have a heater and doesn't appear to have came from the factory with the heater as it is blocked off from the inside. Again, someone that is more familar with Mopars can comment on that.
The bad news is that this car needs a paint job as the quarter panels are wavy and has filler near the bottom edges. Also the car needs floor pans and trunk braces to make nice. The Interior, Under Hood, and Stainless Trim on the car is in decent shape.
Asking: $9500
Contact: 859-327-0294 days only
Asking: $9500
