[SOLD] 1966 440 w/ 727
brian.linn
Conway Springs
Rating - 0%
0   0   0
1966 440 bored (446cid), stock steel crank and rods, 11.5:1 compression, Howard's Rattler Cam, PN# 728001-09, Hydraulic Flat Tappet 227/235 @ .050, .480/.488, 109LS, less then 50 miles on rebuild. Comes with stock heads (big block chevysprings), MSD Distributor, 6AL Box, rebuilt big block 727 transmission with shift kit, forward, automatic valve body and Hurst 1/4 Shift shifter, TCI Street Fighter Torque Converter. Selling as a package for$3200obo. PM me for pics and a video of the motor running in the car.
are the heads 66 casting as well ? and auto as well ?
I doubt it, I bought the heads from a friend, I had a bolt break off in the head. The engine came with 906 heads that were ported and cut up quite a bit. They have since cracked and would need to be epoxied if ran again. I do have some 452 heads if that would add interest, as well as two 400 blocks.
The 400 are blocks are late 70's, they would be needing rebuilt. I have a set or two of 452 heads, no cranks, pistons or rods...
Also, I believe I just sold the MSD distributor and 6AL box. That's about the extend I would sell separate, would rather keep the rest together.
As of now, the MSD components are still with this motor. $2700 for the lot, including the 400's. I really want this stuff outta my shop!
