[WANTED] 1966 barracuda engine pulleys
cudajoedart
Connecticut
Hi I am looking for lower dual crank pulley for power steering also need a/c bracket with idler pulley adding power steering and a/c to my cuda any help is appreciated
Joe
If you're adding p/s and a/c to an early A-body, then you will need a 3 groove crank pulley,...
One groove for alt and water pump, one for P/S, and one for a/c...
My 65 uses a 4 belt lower pulley and 2 belt water pump pulley - 2 belts for the alternator/AC, 1 for the WP and 1 for the PS
